AEG Power Solutions ACMi1000HD
This protocol allows you to monitor the AEG Power Solutions ACMi1000HD, which is a hot-pluggable, modular, flexible power system controller for DC power systems.
About
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version. - -
Product Info
Range Supported Firmware
1.0.0.x 2.18 (ACM version)
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
SNMP Main Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP of the device.
SNMP Settings:
  • Port number: The port of the connected device, by default 161.
  • Get community string: The community string used when reading values from the device, by default public.
  • Set community string: The community string used when setting values on the device, by default private.
Initialization
No additional configuration is necessary.
Redundancy
The connector does not include any redundancy options.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to Use
The connector uses SNMP calls to communicate with the device.
On the Configuration page, thresholds and limits can be defined.
Notes
To prevent improper use, some of the settings require a group security level of 4. If a user with a lower security level accesses the element, they will only be able to read the values, but they will not be able to make any changes. This applies to the following parameters: Battery Capacity, Discharge Test Mode, Discharge Test Current, Battery Low Voltage Alarm Threshold, Battery Low Voltage Disconnect Threshold, Load LVDNE 1 Disconnect Threshold and Load LVDNE 2 Disconnect Threshold.
