AKCP Environmental Monitoring Unit - Temperature
This exported connector shows the temperature probe data from an AKCP Environmental Monitoring Unit.
About
This connector is automatically generated by the connector AKCP Environmental Monitoring Unit, range 1.0.0.x.
Product Info
| Range | Supported Firmware Version |
| 1.0.0.x | SP8463 |
Installation and configuration
A DVE using this connector is automatically created by an element using the parent connector, if a DVE is activated on a temperature sensor.
Usage
General
This page contains all the exported parameters:
- ID: SNMP instance of the sensor in the sensor table.
- Sensor Description: The description reported by the device.
- Status: The sensor's status. N/A in case there is no value, No Status in case the sensor is removed on the device.
- Temperature: The measured value in degrees Celsius.
- DVE Name: The name of the DVE. This name must be unique in the DMS. If the name is already present in the sensor table, it will be appended with a number when edited.
