APA Sound Monitoring
This connector can be used to interact with a media monitoring solution from APA-Comm. Test results of radio streams, podcasts, and audio streams are available for each different test device. Current audio streams, e.g., podcasts, are available for each channel.
About
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version - -
Product Info
Range Supported Firmware
1.0.0.x -
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
HTTP Connection
This connector uses an HTTP connection and requires the following input during element creation:
HTTP CONNECTION:
  • IP address/host: The polling IP or URL of the destination.
  • IP port: The IP port of the destination, default: 80.
How to Use
General page
On the left side of this page, the standalone parameters from the RadiothekMonitor link are shown:
  • Last Streams Update
  • Last Check Duration
  • Overall Status
  • Response times
On the right side of this page, you can configure the polling speed of the requests.
The device monitoring result sends two requests, one for the Android and one for the iOS results.
Stream Loader page
This page contains the Stream Loader table. You can configure how rows with row status Deleted will be processed.
The subpages of this page contain the SQL Query Result table and the Podcast table.
If you delete a stream loader, the children of this stream in the Podcast table and SQL Query table will also be deleted.
Streams page
This page contains the Streams table. You can configure how rows with row status Deleted will be processed. In addition, you can also trigger the immediate polling of the data.
The subpages of this page contain the Device table and the Device Tests table.
If you delete a stream, the children of this stream in the Device table will be deleted, and the children of the device in the Device Tests table will be deleted.
Podcast subpage
This subpage contains standalone parameter Auto Delete Time and Podcast table.
When the date in the Date column of the Podcast table is older than the current date and time minus the Auto Delete Time, and the row has the Deleted status, this row will be deleted automatically.
If Auto Delete Time is set to No Auto Delete, no rows will be deleted automatically.
