Active Power CleanSource XT MMS
About
The Active Power CleanSource XT MMS connector enables DataMiner integration and monitoring of Active Power's CleanSource XT Multi-Module System (MMS). Through SNMP, this connector retrieves operational and performance data from the device and all added modules.
Key Features
  • Remote monitoring: Monitor the Active Power CleanSource XT MMS remotely via DataMiner.
  • Trending: Configure trending to keep track of the trends in the retrieved data.
  • Alarming: Get notified of any issues or potential issues through proactive monitoring and issue detection.
Use Case
Challenge: Operators need to ensure continuous uptime by monitoring multiple Active Power CleanSource XT MMS devices across various locations.
Solution: Use the Active Power CleanSource XT MMS connector to integrate these devices into DataMiner, enabling real-time off-site monitoring of all operational parameters and alarms.
Benefit: Early detection of potential issues and proactive maintenance, leading to improved uptime and reliability of the power systems.
Technical Reference
For detailed technical information, refer to our technical documentation.
