Advantech AMT Monitor and Control Panel
This is an SNMP connector that shows the status of the different parameters of an Advantech AMT Monitor and Control Panel.
The Advantech AMT Monitor and Control Panel consists of a control panel and several modules (SSPAs, Transceiver).
The connector shows all information in table format, the same way as it is stored in SNMP. This is also the case even if a table only consists of one row. There is no web interface to control the device.
About
Version Info
Range Description DCF Integration Cassandra Compliant
1.0.1.x Initial version. No Yes
1.0.2.x DVE integration. No Yes
1.1.0.x [Obsolete] Removed parameters that were not working. No Yes
1.2.0.x [SLC Main] New MIBs OIDs change; parameters removed. No Yes
Product Info
Range Supported Firmware
1.0.2.x Unknown
1.1.0.x Unknown
1.2.0.x Software version V0000 (180613)
Exported Connectors
Exported Connector Description
Advantech AMT Monitor and Control Panel Unit SSPAs, Transceiver. Not in the 1.2.0.x range.
Configuration
Connections
SNMP Main Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP of the device, e.g., 10.11.12.13.
SNMP Settings:
  • Port number: The port of the connected device, by default 161.
  • Get community string: The community string in order to read from the device. The default value is public.
  • Set community string: The community string in order to set to the device. The default value is private.
How to Use
General
This page contains general configuration information for the interfaces of the device: the Unit Serial Number, PS Voltages, Shroud Temperature, and Port and MAC information of the Defined Units.
There is also a Reset Control Panel option.
Units
This page contains information about the connected units. It also allows you to configure the creation of DVEs and the names of the exported elements.
Switches (No Longer available for range 1.2.0.x)
This page contains the status of the switches connected to the device.
Network
This page contains network information including IP, UDP, and Interfaces.
