Advantech Wireless Remote Monitor and Control Panel 1-2 Redundant SSPB (BUC) System
This Monitor and Control Panel is used for redundant high-power units, monitoring the status of two SSPB units in a redundant system and three amplifiers in a 1-to-2 redundant phase-combined configuration, and providing control to the RF units.
About
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version - -
Product Info
Range Supported Firmware
1.0.0.x -
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
SNMP Connection - Main
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP of the device.
SNMP Settings:
  • Port number: The port of the connected device, by default 161.
  • Get community string: The community string used when reading values from the device, by default public.
  • Set community string: The community string used when setting values on the device, by default private.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to Use
This connector uses SNMP parameters and tables to retrieve data from the device.
