Alpha Combi UPS AC DC
About
The Alpha Combi UPS AC DC connector enables monitoring of an uninterruptible power supply system. It allows operators to oversee the power system health and performance through a centralized interface.
Configuration
Connections
SNMP Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
- IP address/host: The polling IP or URL of the destination.
- IP port: The IP port of the destination.
SNMP Settings:
- Get community string: The community string used when reading values from the device (default: public).
- Set community string: The community string used when setting values on the device (default: private).
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
Once the element has been configured, the connector will automatically begin polling data from the device via SNMP. It retrieves information on the power system status, network interfaces, rectifier and inverter modules, and battery health.
On the data pages, you can find the following information:
- General: Overview of the UPS system, including the controller information.
- Interfaces: Overview of the network interfaces, along with the overall status and traffic information.
- Rectifier: Information regarding the voltage and current levels and the overall status of the rectifier module.
- Battery: Overview of all the battery parameters, including voltage, current, temperature, and capacity
- Inverter: The general, output, and input parameters of the inverter module.
- Cordex HP Controller: Comprehensive view of all the parameters available from the device controller.
