Arris CHP Max5000 - CHP-FANS
The CHP-FANS contains information related to all the fans that are present in a specific chassis (CMM Card). This is not a physical card, but Arris maps all the fans from a specific chassis (monitored by a CMM card) using a different card type (CHP-FANS). Multiple chassis can be connected in a daisy chain, with each chassis containing up to 8 fans.
About
This is an SNMP connector, which uses SNMP polling to communicate with the physical devices.
Product Info
| Range | Supported Firmware Version |
| 1.0.0.x | 1.0.6.0 |
Installation and configuration
Creation
This connector is used by DVE child elements that are automatically created by the connector Arris CHP Max5000, from version 1.0.0.6 onwards.
Usage
General
This page contains card-specific hardware information and configuration options.
Fans
This page displays a table with information on the fans associated with a specific chassis.
