Control By Web X-600M
This connector retrieves the state and performs minor control functions of Control By Web modules attached to the X-600M.
Configuration
Connections
HTTP Main Connection
This connector uses an HTTP connection and requires the following input during element creation:
HTTP CONNECTION:
- IP address/host: The polling IP or URL of the destination.
- IP port: The IP port of the destination (fixed value: 80).
- Device address: The bus address of the device. If the proxy server has to be bypassed, specify BypassProxy.
SNMP Traps Connection
This connector uses a Simple Network Management Protocol (SNMP) connection to receive traps and requires the following input during element creation:
SNMP CONNECTION:
- IP port: The IP port of the destination (default: 162).
SNMP Settings:
- Get community string: The community string used when reading values from the device (default: public).
- Set community string: The community string used when setting values on the device (default: private).
Initialization
If the device has Dashboard and I/O Password Protection enabled, then the username and password must be inserted on the General page.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
Once a valid username and password have been specified, content is retrieved and shown in the tables.
Some control of the relays is available, and data is displayed depending on how the X-600M is configured for each Control By Web device.
Note: Configuration of the names can break the handling of data, so we highly recommend using the default names of each KPI.
