Crystal Vision Vision 3 Frame - Tandem 10 VF
This exported connector shows data from a TANDEM10-VF module in a Crystal Vision Vision 3 Frame.
TANDEM10-VF provides a solution for audio embedding and de-embedding for use with Vision rack frames from Crystal Vision. It has a single SDI video path with a de-embedder and an embedder, which allow the extraction and insertion of up to 16 channels (four groups) of audio.
About
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x [SLC Main] | Initial version | - | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | 1.2.0 |
Configuration
This SNMP connector is used by DVE child elements that are automatically created by the parent connector Crystal Vision Vision 3 Frame.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
General: Displays status information related to the DVE, as well as information about video, sub PCB type and audio.
Video: Allows you to configure video parameters related to delay and output, RGB processing (including color gain and lift), YUV processing, VANC blank enabling and fiber input.
Audio:
Contains the DeEmbedded Input Table and Discrete Inputs Table, which allow you to enable or disable parameters like Invert, Dolby or ReSample for each audio group or discrete input.
- Contains the Delays Table for de-embedded inputs and discrete inputs, where you can enable parameters such as Frame Delay and User Delay.
- Allows you to configure PCM Audio Delay and AES Inputs/Outputs.
- The Audio Gains subpage allows you to configure gains for de-embedded inputs and for discrete inputs.
Audio Router:
Allows you to enable the outputs for the different audio groups and configure the embedder mode.
- The Mutes subpage allows to mute each of the embedded channels and AES outputs individually.
Presets Default Alarms:
Allows you to select, store and recall presets, or return to a default preset.
- Allows you to configure alarm delays for Video Black, Video Frozen, Audio Silence and Audio Silence Level.
