Deep Sea Electronics DSE8620 MkII
About
The Deep Sea Electronics DSE8620 MkII is a control unit designed for generator electrical panels.
Configuration
Connections
Serial Main Connection
This connector uses a serial connection and requires the following input during element creation:
SERIAL CONNECTION:
  • Interface connection:
    • IP address/host: The polling IP or URL of the destination.
    • IP port: 502
    • Bus address: 1
How to use
The element created with this connector consists of the data pages detailed below.
General
On this page, you can upload the following CSV files:
  • Modbus List: File with the register address, description, multiplier, and units of the parameters. This file must be created manually based on information from the manual.
  • Three files that can be exported from the device, containing the address and description of the parameters.
Modbus Data Table
This page displays information about the Modbus CSV file.
Data
On this page, you can view information from the device according to the parameters uploaded from the CSV file.
