Eaton Remote Power Panel
The Eaton RPP connector is used to monitor the Eaton Remote Power Panel.
About
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version. Monitors the EATON RPP system. - -
Product Info
Range Supported Firmware
1.0.0.x v2.24
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
SNMP Main Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP or URL of the destination.
  • IP port: Default:161.
SNMP Settings:
  • Get community string: Default: public-community.
  • Set community string: Default: private-community.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
On the Overview page, you can find a tree control that shows the relationship between the panel and breaker.
On the RPP page, you can find:
  • General RPP information.
  • The Breaker table, containing detailed information on breaker ratings, meters, and phase meters.
  • The Panel table, containing detailed information on each panel.
On the Power Chain Device page, you can find the PCD Digital Inputs table, which shows the digital inputs for each power chain device.
