Generac Power Systems SG050T Generator
This connector monitors the engine and generator parameters of the SG050T generator.
About
Version Info
Range Features Based on System Impact
1.0.0.x [SLC Main] Initial version - -
Product Info
Range Supported Firmware
1.0.0.x 1.21.4
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
Modbus Communication
This connector uses a serial connection and requires the following input during element creation:
SERIAL CONNECTION:
  • Direct connection:
    • Baudrate: Baudrate specified in the manual of the device, e.g., 9600 (default: 9600).
    • Databits: Databits specified in the manual of the device, e.g., 7 (default: 8).
    • Stopbits: Stopbits specified in the manual of the device, e.g., 1 (default: 1).
    • Parity: Parity specified in the manual of the device, e.g., No (default: even).
    • FlowControl: FlowControl specified in the manual of the device, e.g., No.
  • Interface connection:
    • IP address/host: The polling IP or URL of the destination.
    • IP port: The IP port of the destination.
    • Bus address: The bus address of the device (default: 1).
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
The connector has two pages, containing only read-only parameters:
  • General: Displays the engine information.
  • Generator Info: Displays the generator information.
