General Dynamics Generic-BDC Redundancy Controller
The VertexRSI 1:2 Redundant Converter System is designed for installation in satellite earth stations. The system consists of three block downconverters (-1201 models) or block upconverters (-1202 models) in a 1:2 redundant configuration, including automatic switchover logic, redundant power supplies, and redundant AC line inputs. The system monitors the status of its converters and switches the standby unit online when a failure of either primary unit is detected.
About
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x [SLC Main] | Initial version | - | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | 1.092 |
System Info
| Range | DCF Integration | Cassandra Compliant | Linked Components | Exported Components |
| 1.0.0.x | No | Yes | - | - |
Configuration
Connections
Serial Connection
This connector uses a serial connection and requires the following input during element creation:
SERIAL CONNECTION:
Direct connection:
- Baudrate: Baudrate specified in the manual of the device, e.g., 9600 (default: 19200). Range: 300 - 28800.
- Databits: Databits specified in the manual of the device, e.g., 7 (default: 8).
- Stopbits: Stopbits specified in the manual of the device, e.g., 1 (default: 1).
- Parity: Parity specified in the manual of the device, e.g., No (default: no).
- FlowControl: FlowControl specified in the manual of the device, e.g., No. (default: no).
Interface connection:
- IP address/host: The polling IP or URL of the destination.
- IP port: The IP port of the destination.
- Bus address: The bus address of the device (range: 0 - 255).
How to use
The General page displays information about the type of product, the firmware, the power supplies, and the Remote and Auto mode.
The Configuration page allows you to configure some device settings.
Depending on the system configuration, the switch positions can be checked and configured on the System Positions and System Switch Control pages.
Other monitoring parameters can be found on the Alarms and Faults pages.
