Generic Satellite Spectrum Monitor
About
This protocol was created to connect with a particular database and with certain elements.
The database contains information that is needed for the protocol to create presets, spectrum scripts and spectrum monitors. The spectrum scripts also do calls to an automation script, which does sets on the ACU, Beacon Receiver and RF Switch element. The monitor then stores the trace in the history database. This makes it possible to cross reference outages with history spectrum traces.
Version Info
Range Description DCF Integration Cassandra Compliant
1.0.0.x Initial version No Yes
Installation and configuration
Creation
Virtual connection
This connector uses a virtual connection and does not require any input during element creation.
Usage
General
This page provides an overview of the elements that can be selected to be used in the spectrum monitoring. It also contains configuration parameters that can be used to configure the database connection.
Database
This page displays the data present in the tables retrieved from the database.
