Gude Expert Power Control NET 24x
The Gude Expert Power Control Net 24x is a 24-fold remote power switch for TCP/IP networks.
About
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] - Initial version.
- Supports GUDEADS-EPC24X-MIB.
Product Info
Range Supported Firmware
1.0.0.x N/A
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Configuration
Connections
SNMP Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP or URL of the destination.
  • IP port: The IP port of the destination (default: 161).
SNMP Settings:
  • Get community string: The community string used when reading values from the device (default: public).
  • Set community string: The community string used when setting values on the device (default: private).
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
An SNMP connection is used to retrieve the device information. SNMP traps can be retrieved when this is enabled on the device.
The connector displays information on the EPC power ports, banks, and fuse status.
Traps configuration is also available.
