MX1 Developed Playout Engine - Ingest
This exported connector is used to monitor the media ingest channels.
About
This connector is exported from the MX1 Developed Playout Engine connector.
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version. - -
Product Info
Range Supported Firmware
1.0.0.x Unknown
Configuration
Initialization
These exported elements are defined in the Ingest Hosts table on the General page of the main element.
How to use
On the General page of this virtual element, you can find general communication settings.
An overview of the operational status of the host managed ingest channels is available on the Ingest page.
More info on the media ingest and content services status can be found on the Ingest Status page.
A web interface page is not available.
