MX1 Developed Playout Engine - Playout
This exported connector is used to monitor the operational status of the playout channels.
About
This connector is exported from the MX1 Developed Playout Engine connector.
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version. - -
Product Info
Range Supported Firmware
1.0.0.x Unknown
Configuration
Initialization
These exported elements are defined in the Playout Hosts table on the General page of the main element.
How to use
On the General page of this virtual element, you can find general communication settings.
An overview of the operational status of the host managed playout channels is available on the Playout page.
Notes
A web interface page is not available.
