MX1 Developed Playout Engine - TS Monitoring
This exported connector is used to monitor the overall state of the media transport streams.
About
This connector is exported from the MX1 Developed Playout Engine connector.
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x [SLC Main] | Initial version. | - | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | Unknown |
Configuration
Initialization
These exported elements are defined in the TS Monitoring Hosts table on the General page of the main element.
How to use
On the General page of this virtual element, you can find general communication settings.
Detailed information regarding the host managed transport streams is available on the TS Details page.
More info on the host monitoring status can be found on the TS Status page.
Notes
A web interface page is not available.
