Mitec Antenna Switch Control Unit
The 216945-001MD Antenna Switch Control Unit is a microcontroller-based unit designed to monitor and control switching/combining system waveguide switches.
About
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x [SLC Main] | Initial version. | - | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | 216945-001MD |
System Info
| Range | DCF Integration | Cassandra Compliant | Linked Components | Exported Components |
| 1.0.0.x | No | Yes | - | - |
Configuration
Connections
Serial connection - Main
This connector uses a serial connection and requires the following input during element creation:
SERIAL CONNECTION:
Direct connection:
- Baudrate: 9600 (default)
- Databits: 7 (default)
- Stopbits: 1 (default)
- Parity: Even (default)
- FlowControl: No (default)
Interface connection:
- IP address/host: The polling IP or URL of the destination.
- IP port: 8013 (default)
- Bus address: 30 (default)
How to use
The Status page displays the switch positions. You can change the switch position (position 1/position 2) by clicking the Set SW X Position button for the corresponding switch.
