Nevion Flashlink Frame - 10G-TR-2
This exported connector shows data from a 10G-TR-2 module in a Nevion Flashlink frame. This module is a bi-directional 10 Gbps optical transponder. It is used to bridge between different optical systems.
About
This is an SNMP connector that is automatically generated by the parent connector Nevion Flashlink Frame.
Version Info
| Range | Description | DCF Integration | Cassandra Compliant |
| 1.0.0.x | Basic range. | No | Yes |
| 2.0.0.x | Tree controls added to monitor parameters. | No | Yes |
| 2.0.1.x | Audio Block status fix (ONLY for firmware 2.0.4). | No | Yes |
| 2.0.2.x | Changed naming structure. | No | Yes |
| 2.0.3.x | Added "card location" and "label" to description column (for all tables). | No | Yes |
Product Info
| Range | Supported Firmware Version |
| 2.0.3.x | 5.0.4 |
Installation and configuration
Creation
This connector is used by DVE child elements that are automatically created by the parent connector Nevion Flashlink Frame.
Usage
General Page
This page contains general information about a 10G-TR-2 module, including:
- Type
- Card Status
- Chassis Number
- Slot Number
- Label
- Alarm Status
- Alarm Trap
- Alarm Count
- Main Element Name
- Active Alarms in System
Laser
This page displays the Laser Table, which contains information about laser parameters.
Optical Input
This page displays the Optical Input table, which contains information about optical input parameters.
It also allows you to view the Opt Input, Input Status and Signal Strength, as well as to configure the Opt Input Alarms.
Reclocker
This page displays the Reclocker Table, which contains information about reclocker parameters.
It also allows you to view the Reclocker Num, Status and Bit Rate, as well as to configure Config, ASI, Bandwidth and Alarms.
Temperature
This page displays the Temperature Table, which contains information about temperature measurements.
It also allows you to configure the Nominal value, Upper and Lower Limit and Alarms, as well as to view the actual temperature Value.
Voltage
This page displays the Voltage Table, which contains information about voltage measurements.
It also allows you to configure the Upper and Lower Limit and Alarms, as well as to view the Nominal effect and the Value in volt and watt.
