Omneon Spectrum System - Device
This connector allows you to monitor this specific device from Omneon Spectrum System.
About
In this connector, data is retrieved using SNMP protocol, every 40 seconds. This connector is automatically generated by connector Omneon Spectrum System from range 2.0.0.x onwards.
Product Info
| Range | Supported Firmware Version |
| 2.0.0.x | 4.5 |
| 2.0.1.x | 4.5 |
Installation and configuration
Creation
This connector is used by DVE child elements that are automatically created by the parent connector Omneon Spectrum System, from version 2.0.0.1 onwards.
Usage
Main View
This page displays the general information about this device with the following parameters: Device ID, Device Name, Device Status, Info Event, Warning Events, Error Events, Critical Events and Trap Details.
Player Info
This page displays the Player Table with information about the players registered for this device. This table has Name, Status, Director Name - which corresponds to the Device Name, Info Events, Warning Events, Error Events and Critical Events columns.
Enclosure Info
This page displays the Enclosure Table with information about the Enclosures (MediaStores) registered for this device. This table has GUID, Name, Status, Director Name - which corresponds to the Device Name, Info Events, Warning Events, Error Events and Critical Events columns.
