STS LNA Monitor and Control
DataMiner connector to monitor and control an STS LNA Controller.
About
This connector doesn't communicate directly with a device. Element connections are used to link parameters from this connector with contacts of an IO box driver.
Some parameters show the combined status of multiple IO contacts as a single parameter.
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x [SLC Main] | Initial version | - | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | - |
System Info
| Range | DCF Integration | Cassandra Compliant | Linked Components | Exported Components |
| 1.0.0.x | No | Yes | - | - |
Installation and configuration
Creation
Virtual connection
This connector uses a virtual connection and does not require any input during element creation.
Configuration of the remote contacts
After creating an element, it must be linked with an IO contacts device, i.e., Advantech ADAM. This must be done via the "Element Connections" application in DataMiner Cube. For more information see the DataMiner help.
Usage
General
This page shows all parameters that have to do with the LNA controller. Some parameters show the combined status of multiple IO contacts.
Contacts
This page displays all parameters that are linked with the external IO contacts device.
