Sony MKS Remote Control Panel
This is an SNMP connector that is used to monitor and configure the Sony MKS-R3210, MKS-R1620, and MKS-R1630 equipment.
About
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x | Initial version | - | - |
| 1.0.1.x [SLC Main] | Added DCF support | 1.0.0.4 | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | 1.10 |
| 1.0.1.x | 1.10 |
System Info
| Range | DCF Integration | Cassandra Compliant | Linked Components | Exported Components |
| 1.0.0.x | No | Yes | - | - |
| 1.0.1.x | Yes | Yes | - | - |
Configuration
Connections
SNMP Main Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
- IP address/host: The polling IP or URL of the destination.
- IP port: The IP port of the destination.
SNMP Settings:
- Get community string: The community string used when reading values from the device (default: public).
- Set community string: The community string used when setting values on the device (default: private).
Initialization
No extra configuration is needed.
Redundancy
There is no redundancy defined.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
General
This page displays the System Information, including the System Time, System Description, System Location, System Contact, System Up Time, and other general parameters.
Network
This page displays the Interfaces table. This table displays the operational status of the interfaces available in the workstation. This operational status can also change based on incoming traps.
Product Information
This page displays the Product Information, Module, and Remote Maintenance tables.
Traps
This page displays the Traps Destination table.
Alarms
This page displays the Error Status table. This table is cleared when a "Coldstart" trap is received.
