Sony Signal Processing Unit - NXLK-IP41F
The Sony NXL-FR316 and Sony NXL-FR318 are processing units (chassis) to which different cards can be attached:
  • IP converter boards: Sony NXL-IP40F/41F/42F/45F/50Y
About
This connector is designed to monitor the state of the IP converter board that can be connected to a Sony NXL-FR316 and Sony NXL-FR318, using SNMP communication.
This connector is exported by the parent connector Sony Signal Processing Unit, from version 1.0.0.x onwards.
Version Info
Range Key Features Based On System Impact
1.0.0.x Initial version - -
1.0.1.x [SLC Main] New feature is for card IP50Y only 1.0.0.14 Button parameters renamed
Product Info
Range Supported Firmware
1.0.0.x V1.00
1.0.1.x V1.00
Configuration
This connector is used by DVEs that are automatically created by the parent element. No user input is required.
Redundancy
There is no redundancy defined.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
Status
This page displays detailed status information on the module, including the Device ID, Manufacturer, Model, Destination, Serial Number, Category, Version, Model Suffix and Version Suffix.
Alarms
This page displays the Error Statuses connected to this module.
NMI / NMI Device
The NMI page in range 1.0.0.x has been renamed to NMI Device page in range 1.0.1.x, by means of an export rule.
This page allows you to connect this IP board to the selected NMI.
Note: Only 1 NMI element can be connected to 1 IP board connected to this chassis. You can check which NMI element is connected to which IP board via the NMI table (in range 1.0.0.x) or IP AV Interface table (in range 1.0.1.x) of the main element.
