Sony Signal Processing Unit
The Sony NXL-FR16 and Sony NXL-FR318 are processing units (chassis), to which the following cards can be attached:
- IP converter boards: Sony NXL-IP40F/41F/42F/45F/50Y
About
Version Info
| Range | Key Features | Based on | System Impact |
| 1.0.0.x | Initial version. | - | - |
| 1.0.1.x | Support for monitoring of Sony 2110 Device Interfaces. | 1.0.0.14 | NMI logic made generic to support other types of interfaces. NMI table renamed to ipAvInterfaces. Columns of Device table referring to NMI now have more generic naming/description. Export rules were adapted. |
| 1.0.2.x [SLC Main] | Added DCF support. | 1.0.1.9 | - |
Product Info
| Range | Supported Firmware |
| 1.0.0.x | V2.61 |
| 1.0.1.x | V2.61 |
| 1.0.2.x | V2.61 |
System Info
| Range | DCF Integration | Cassandra Compliant | Linked Components | Exported Components |
| 1.0.0.x | No | Yes | - | Sony Signal Processing Unit - NXLK-IP41F Sony Signal Processing Unit - NXLK-IP42F Sony Signal Processing Unit - NXLK-IP40F Sony Signal Processing Unit - NXLK-IP50Y Sony Signal Processing Unit - NXLK-IP45F |
| 1.0.1.x | No | Yes | - | Sony Signal Processing Unit - NXLK-IP41F Sony Signal Processing Unit - NXLK-IP42F Sony Signal Processing Unit - NXLK-IP40F Sony Signal Processing Unit - NXLK-IP50Y Sony Signal Processing Unit - NXLK-IP45F |
| 1.0.2.x | Yes | Yes | - | Sony Signal Processing Unit - NXLK-IP41F Sony Signal Processing Unit - NXLK-IP42F Sony Signal Processing Unit - NXLK-IP40F Sony Signal Processing Unit - NXLK-IP50Y Sony Signal Processing Unit - NXLK-IP45F |
Configuration
Connections
SNMP Main Connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
- IP address/host: The polling IP or URL of the destination.
- IP port: The IP port of the destination.
SNMP Settings:
- Get community string: The community string used when reading values from the device (default: public).
- Set community string: The community string used when setting values on the device (default: private).
Initialization
No extra configuration is needed.
Redundancy
There is no redundancy defined.
Web Interface
The web interface is only accessible when the client machine has network access to the product.
How to use
Range 1.0.0.x
The element created with this connector has the following data pages:
- General: This page contains general information, such as the System Description, System Up Time, System Contact, Name, and Location. It also displays an overview of the OSI Model of the availability of each layer and the Electricity Consumption, PSU Fan A Total Up Time, PSU Fan B Total Up Time, Chassis Fan A Total Up Time, and Chassis Fan B Total Up Time.
- Network: This page displays the Interfaces and Address Translation tables. The operational status of the interfaces can also be updated based on incoming traps.
- Product Information: This page displays the Product Information, Modules, and Remote Maintenance tables. The Product Information Table is used to extrapolate data to create the DVEs.
- Traps: This page displays the Traps Destination table.
- Alarms: This page displays the Error Status table. This table is both polled and updated based on traps. The table is cleared when a "Coldstart" trap is received.
- DVE: This page displays the DVE tables and the setting to automatically delete DVEs.
- NMI: On this page, the NMI table allows you to check which interface element is connected to which card. The Resubscribe button can be used to reset all the created subscriptions. In this range, the only supported IP IV interface is the Sony NMI device.
Range 1.0.1.x
- IP IV Interface: On this page, the IP IV Interfaces table allows you to check which interface element is connected to which card. The Resubscribe button can be used to reset all the created subscriptions. In this range, the supported IP IV interfaces are the Sony NMI device and Sony 2110 device.
Notes
**IMPORTANT NOTE: **The index of the Product Information Table and the Device table has a difference of -1 with the DVE element names. DVEs have an element name of the format MainElementName-Module_Slot No, with "Slot No" being PK Product Information Table - 1.
Example: Main Element: Sony NXL-FR316
Product Information table: Key Module DVE Element Name 2 NXLK-IP40F Sony NXL-FR316-NXLK-IP40F_1
