Valere Power DC Power System
The Valere Power DC Power System is a power supply unit.
About
This connector allows you to retrieve information from a Valere PSU. It allows you to monitor alarm and statistical information, and to configure and activate the device.
The connector retrieves and sets information on the device through SNMP.
Version Info
Range Key Features Based on System Impact
1.0.0.x [SLC Main] Initial version - -
Product Info
Range Supported Firmware
1.0.0.x 24.03.36
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
Installation and configuration
Creation
SNMP Main connection
This connector uses a Simple Network Management Protocol (SNMP) connection and requires the following input during element creation:
SNMP CONNECTION:
  • IP address/host: The polling IP of the device.
  • Device address: Not required.
SNMP Settings:
  • Port number: The port of the connected device, by default 161.
  • Get community string: The community string used when reading values from the device, by default public.
  • Set community string: The community string used when setting values from the device, by default private.
Usage
System
This page contains general information about the device.
It also contains a number of page buttons:
  • System Config: Allows you to configure system temperature compensation settings and internal temperature thresholds.
  • Rectifier Config: Allows you to configure the Rectifier Float Voltage Setpoint and Rectifier High Voltage Shutdown Setpoint.
  • LVD Configuration: Displays the LVD settings.
Battery
On this page, the Battery Temperature table allows you to monitor the battery temperature if probes are connected. The Thermal Probe table displays the thermal probe status.
Via the Battery Config page button, you can configure the battery temperature settings.
Alarm
On this page, you can monitor and configure the alarms in the device.
SNMP Configuration
This page contains a table with traps settings and allows you to configure the Read/Write/Trap Community String settings.
