Vodafone Kabel Deutschland GmbH FRR on OpenShift
About
This is a dedicated connector to interface with a Red Hat OpenShift cluster and underlying PODs by utilizing the OpenShift CLI Tooling (OC Tool). The Free Range Routing (FRR) is a dedicated network routing suite under the OpenShift cluster hosting all instances to manage and deploy the network routes within the cluster.
To interface with OpenShift, a dedicated CLI tool is utilized, which must be available and installed on each DataMiner Agent where an element using this protocol is hosted. Refer to the official Red Hat documentation.
Configuration
Connections
Virtual Connection
This connector uses a virtual connection and does not require any input during element creation.
The endpoint details are configured under the Connection Settings page on the element, where you can also provide the Authentication Token (Service Account). These will be used when the required commands are performed with the OC Tool to fetch or configure the data.
How to use
General Page
The General page displays an overview of the available PODs and all Active Routes.
On the Configuration page, the table actions allow you to add, sync, and remove routes on all PODs. You can interface with each table by right-clicking it to access the context menu.
The Poll Settings page allows you to configure the polling interval per integrated command. It also shows a status that indicates if the command was successful or else shows the error response.
