Vodafone Kabel Deutschland GmbH POC Tally
About
This is a dedicated connector intended to aggregate the SI system status of the different lineups and systems.
The POC tally status is determined for each SI stream, so its status can be shown as On-Air, Off-Air, On-Air Locally, Off-Air Locally, On-Air Locally Inverted, or Off-Air Locally Inverted.
Configuration
Connections
Virtual Connection
This connector uses a virtual connection and does not require any input during element creation.
How to use
General Page
The General page displays the aggregated tally status information per lineup, site, and system.
On the following pages, you can see the status of each lineup or system individually:
- iSIMS System
- National MUX
- Catweazle RegioMUX
You can interface with each table by right-clicking it to access the context menu.
User-Defined API Endpoint
The connector comes with a user-defined API endpoint so that it is possible to not only retrieve the status data within DataMiner but also from external systems: {DMA IP}/api/custom/poc-tally.
