Forcing a DataMiner Agent to work without virtual IP addresses
In the file DataMiner.xml, you can order a DataMiner Agent not to use virtual IP addresses.
To do so:
  1. Stop DataMiner.
  2. Open the file C:\Skyline Dataminer\DataMiner.xml.
  3. Add a disableElementIP attribute to the <DataMiner> tag, and set it to “true”.
    By default, the disableElementIP attribute is set to “false”.
  4. Save the file and restart DataMiner.
If the disableElementIP attribute is set to “true”, after a restart of the DataMiner Agent, it will no longer be possible to assign a virtual IP address to an element. Moreover, the virtual IP addresses of all existing elements will be disabled.
Example:
<DataMiner disableElementIP="true" >...</DataMiner>
