Antivirus on the DataMiner Agents
Prior to DataMiner 10.4.12/10.5.0 [CU10], this BPA test is called "Check Antivirus DLLs".
When installed on a DataMiner Agent, antivirus software must be configured to exclude the DataMiner processes.
The Antivirus on the DataMiner Agents BPA test specifically detects the presence of antivirus DLLs loaded into DataMiner processes (SL*.exe hosted from the C:\Skyline DataMiner\Files folder). You can find information about this BPA test below.
This BPA test is available by default from DataMiner 10.1.4 onwards.
Metadata
  • Name: Antivirus on the DataMiner Agents
  • Description: Verifies that no antivirus DLLs have been loaded into DataMiner processes
  • Author: Skyline Communications
  • Default Schedule: Every day
Results
Success
No antivirus DLLs found
This is the result when none of the running SL*.exe processes have a known antivirus DLL loaded.
Error
Found antivirus DLL in SLXXXX: [dllname]. To resolve, exclude DataMiner processes (SL*) from antivirus checking.
Note that there will only be one DLL reported for one process. The test quits as soon as it finds one DataMiner process hosting an antivirus DLL.
Warning
This BPA does not generate warnings.
Not Executed
These are the messages that can appear when the test fails to execute for unexpected reasons and cannot provide a conclusive report because of this:
Could not execute test ([message]) (on unexpected exceptions).
In the message above, the exception message is included (e.g., "Access Denied"). The test result details contain the full exception text, if available.
Impact when issues detected
  • Impact: Operation of the DataMiner System might be affected by the antivirus software.
  • Corrective action: Please configure the antivirus software to exclude DataMiner processes (sl*.exe).
As some antivirus software injects itself into the DataMiner processes, it may be necessary to also restart DataMiner to resolve this error.
List of DLLs being checked
The following DLLs are currently checked (case insensitive):
Fixed names
  • UMEngx86.dll (Symantec)
  • TmUmEvt.dll (Trend Micro)
  • tmmon.dll (Trend Micro)
  • sophos_detoured_x64.dll (Sophos AV)
  • sysfer.dll (Symantec endpoint Protection)
Regular expressions
  • ^(?:CrowdStrike\.Sensor\.)?ScriptControl(?:32_|64_|86_)?\d+\.dll$ (CrowdStrike — only included prior to DataMiner 10.5.0 [CU10]/10.6.0/10.6.1)
  • ^ScriptSn\.\d+\.dll$ (McAfee)
File path checks
From DataMiner 10.3.0 [CU19]/10.4.0 [CU7]/10.4.10 onwards, the BPA test also checks the paths of loaded antivirus DLL files.
This means:
  • The test can detect antivirus DLLs even if they are renamed or newly added, as long as they are loaded from a known antivirus file path.
  • The test takes into consideration both the file name and the source path, which increases the chances of detection.
Limitations
  • The BPA can only check for native DLLs. Managed DLLs cannot be detected.
  • The BPA currently does not check Cassandra or MySQL processes for loaded antivirus DLLs.
