Firewall Configuration
The firewall acts as a "gatekeeper", blocking and monitoring unauthorized requests to a network, server, or application. It is crucial that a "gate" (i.e., a port) is closed if it is not actively being used.
A firewall policy that is too lax may allow adversaries to attack internal services.
This BPA test verifies that no excessive ports are open in the Windows firewall.
This BPA test has been replaced by the Security Advisory BPA test, available from DataMiner 10.3.0 [CU15]/10.4.0 [CU3]/10.4.5 onwards.
Metadata
  • Name: Firewall Configuration
  • Description: Verifies that no excessive ports are open in the Windows firewall
  • Author: Skyline Communications
  • Default Schedule: Daily
Results
Success
No excessive firewall ports are open.
Warning
Too many (or too few) ports are allowed through the Windows firewall, or the firewall is completely disabled.
Errors
This BPA does not create errors.
Mitigation
Restrict the number of ports allowed through the Windows firewall. For more information see Configure the firewall.
Limitations
  • The BPA can only check the local server.
