Starting or stopping a DataMiner node in Cube
Go to Apps > System Center > Agents.
In the Manage tab, select the node you want to (re)start or stop, and click one of the following buttons in the pane on the right:
Button Description Stop Stops the DataMiner software on the selected node. (Re)start Starts or restarts the DataMiner software on the selected node. Shut down Shuts down the server hosting the selected node. Reboot Restarts the operating system of the server hosting the selected node.
- If you shut down a node, you will not be able to start it again by remote control. Someone will have to go where the server is located and start it manually.
- On nodes running recent Windows operating systems, the startup type of the DataMiner services is set to "Automatic (Delayed Start)" by default. This means that DataMiner waits until all Windows services are up and running before launching its own services.
- If you are using a DaaS system, your DMS is fully hosted and maintained by Skyline Communications. As such, from DataMiner 10.3.0 [CU18]/10.4.0 [CU6]/10.4.9 onwards, the Stop, Shut down, and Reboot buttons are no longer available for DaaS.
