Configuring storage per DMA
To have access to all the latest DataMiner features, switching to Storage as a Service (STaaS) is highly recommended. If for some reason you need to continue using self-managed storage even though this is not recommended, you will need to switch to dedicated clustered storage to have access to all features.
If you are still using an older setup with storage per DMA instead of the recommended Storage as a Service (STaaS), typically this will involve a Cassandra database per DMA. In the oldest legacy setups, a MySQL (or MSSQL) database may still be used.
This feature is obsolete. The migration wizard from SQL to Cassandra is no longer supported from DataMiner 10.3.0 [CU6]/10.3.6 onwards.
By default, when you install a new self-managed DataMiner System, a Cassandra database per DMA is configured. If you have an existing legacy DataMiner System with SQL database, migrating to Cassandra will give you access to additional DataMiner features (depending on your DataMiner version), including:
  • Advanced Analytics features such as alarm focus, behavioral anomaly detection, proactive cap detection, automatic alarm grouping, and pattern matching
  • Trend predictions
  • DataMiner Service & Resource Management
  • The Generic Query Interface in DataMiner Dashboards
  • Alarm Console enhancements: heatline columns, reports view
  • Heatmap reports (in the legacy Reporter app)
storage per DMA
MySQL database
On legacy DataMiner Systems, typically a MySQL (or MSSQL) database is used as the general database. To have access to all the latest DataMiner features, switching to Storage as a Service (STaaS) is highly recommended. For this, you first need to migrate to Cassandra. If you choose to keep using self-managed storage, switching to dedicated clustered storage is highly recommended.
MSSQL is no longer supported as the general database as from DataMiner 10.3.0.
