Advanced Failover options
When you click Advanced in the Failover dialog box, a window opens with several tabs where you can configure advanced options.
Some Failover options can also be configured directly in MaintenanceSettings.xml. For more information, refer to MaintenanceSettings.SLNet and MaintenanceSettings.WatchDog.FailoverOnRTE.
Type
Go to this tab to specify whether Failover should occur manually or automatically.
  • If you choose Automatic, you must then go to the Heartbeats tab to specify all necessary settings.
  • If you choose Manual, switching can be done with the Switch button at the bottom of the Failover dialog box.
    • Manual switching is not possible when the offline DMA is not running. In that case, the Switch button will be unavailable.
    • If the online DMA becomes unavailable for some reason, you can switch by connecting to the offline DMA with DataMiner Cube. You will then get the option to bring that DMA online.
Synchronization
Go to this tab to configure the network interface for data synchronization from the online DMA to the backup DMA.
  • If there is a third network interface that connects both DMAs using a cross cable, it is advisable to select that one in order to prevent synchronization failures.
  • Note that synchronization of a Cassandra or OpenSearch/Elasticsearch database is taken care of by the database itself, outside of DataMiner.
Heartbeats
Failover Agents use heartbeats to check whether their Failover team mate is still up and running. At regular intervals, both DMAs send heartbeats to each other. When the backup Agent notices that all configured heartbeats have been failing, it will automatically go online. However, if both Agents notice that normal heartbeats are failing, no switch is performed (assuming that the Agents still have a way to communicate).
There are two types of heartbeats:
  • Normal heartbeats: An offline Agent goes online automatically when all normal heartbeats are failing. Normal heartbeats should always be configured for a Failover setup, regardless of whether manual or automatic Failover is used. These will among others determine whether an Agent can go online after a restart.
  • Inverted heartbeats: An Agent goes or remains offline when all inverted heartbeats are failing. This prevents both Agents from going online simultaneously when for instance a network switch between them is down.
    Caution
    • It is important that the inverted heartbeats are configured as well, to avoid issues with both DMAs going online the moment they can no longer contact each other. This can especially be a problem with less recent DataMiner systems.
    • Inverted heartbeats must not be configured with the same IP address as the normal heartbeats, as doing so would create a logical conflict that would prevent both nodes from going online.
Each heartbeat causes a periodical connection check:
  • To a DMA: A DataMiner communication check using IP port 8004. With this type of heartbeat, it is possible to specify the network interface to be used.
  • To an IP address: A ping request is performed.
For every heartbeat you configure, you can specify a maximum number of allowed failures. This way, you can keep the backup DMA from taking over each time a single heartbeat fails for one reason or another.
For detailed information on the preferred heartbeat configuration, refer to Failover configuration in Cube
Virtual IP Addresses
On this tab, you can configure virtual IP addresses for the different network interfaces. These addresses will be moved between agents when switching.
This tab is not available if a shared hostname is used instead of virtual IP addresses.
Advanced Options
This tab is available from DataMiner 10.2.0 [CU5]/10.2.8 onwards. It contains the following option:
  • Auto-restart Agent when going offline: If you select this option, when one of the DMAs in the Failover pair goes offline, it will restart as soon as possible instead of waiting until all elements have been unloaded. This will speed up Failover switching. In earlier DataMiner versions, this could be configured in DMS.xml.
