Custom DataMiner notification
Custom notification OID
Syntax:
1.3.6.1.4.1.8813.1.1.2.3.[Custom suffix]
Custom bindings
Binding OID Comments
Alarm ID 1.3.6.1.4.1.8813.1.1.2.4.1.1
DataMiner ID 1.3.6.1.4.1.8813.1.1.2.4.1.2
Element ID 1.3.6.1.4.1.8813.1.1.2.4.1.3
Parameter ID 1.3.6.1.4.1.8813.1.1.2.4.1.4
Type ID 1.3.6.1.4.1.8813.1.1.2.4.1.5 Possible values:
- Escalated (8)
- Dropped (9)
- New alarm (10)
- Cleared (11)
- Acknowledged (19)
- Resolved (20)
- Unresolved (21)
- Comment Added (22)
- Unmasked (27)
- Dropped from critical (31)
- Dropped from major (32)
- Dropped from minor (33)
- Dropped from warning (34)
- Escalated from warning (35)
- Escalated from minor (36)
- Escalated from major (37)
- Flipped (38)
- Service impact changed (40)
- Value changed (41)
- Name changed (42)
- RCA level changed (43)
- Properties changed (50)
State ID 1.3.6.1.4.1.8813.1.1.2.4.1.6 Possible values:
- Cleared (11)
- Open (12)
- Masked (25)
Severity ID 1.3.6.1.4.1.8813.1.1.2.4.1.7 Possible values:
- Critical (1)
- Major (2)
- Minor (3)
- Warning (4)
- Normal (5)
- Information (13)
- Timeout (17)
- Error (24)
- Notice (28)
Severity range 1.3.6.1.4.1.8813.1.1.2.4.1.8 Possible values:
- Normal (5)
- High (6)
- Low (7)
Previous alarm ID 1.3.6.1.4.1.8813.1.1.2.4.1.9
User status ID 1.3.6.1.4.1.8813.1.1.2.4.1.10 Possible values:
- Not assigned (18)
- Acknowledged (19)
- Resolved (20)
- Unresolved (21)
Alarm root ID 1.3.6.1.4.1.8813.1.1.2.4.1.11
Source ID 1.3.6.1.4.1.8813.1.1.2.4.1.12 Possible values:
- DataMiner (16)
- Correlation engine (23)
- Automation engine (26)
Table display index 1.3.6.1.4.1.8813.1.1.2.4.1.13 What is returned depends on how the table is indexed:
- Primary key only: Returns primary key value.
- Table with naming option, but no display key column: Returns what has been defined with the naming option.
- Table with naming option and column of type DisplayKey: Returns the value in the display key column.
Full RCA level 1.3.6.1.4.1.8813.1.1.2.4.1.14 A 32-bit integer
Up to DMS version 6.0.2:
- Parameter RCA: Bytes 4 and 3
- Element RCA: Bytes 2 and 1
As from DMS version 6.0.3:
- Service RCA: Byte 4
- Parameter RCA: Byte 3
Examples:
- Element RCA = 1, Parameter RCA = 2, Service RCA = 3 >>> Full RCA: 0x03020001
- Element RCA = none, Parameter RCA = 1, Service RCA = 2 >>> Full RCA: 0x0201FFFF
- Element RCA = none, Parameter RCA = none, Service RCA = none >>> Full RCA: 0xFFFFFFFF
Element type 1.3.6.1.4.1.8813.1.1.2.4.1.15
Root time 1.3.6.1.4.1.8813.1.1.2.4.1.16 A fixed time format is used:
"yyyy-mm-dd HH:MM:SS".
Table index (primary key) 1.3.6.1.4.1.8813.1.1.2.4.1.17
Protocol name 1.3.6.1.4.1.8813.1.1.2.4.1.18
Alarm presence 1.3.6.1.4.1.8813.1.1.2.4.1.19
Polling IP 1.3.6.1.4.1.8813.1.1.2.4.1.20 The polling IP address of the element raising the alarm.
Service impact 1.3.6.1.4.1.8813.1.1.2.5.1.1
Element properties 1.3.6.1.4.1.8813.1.1.2.4.4.1.[ASCII values] See Syntax of OIDs referring to properties.
Service properties 1.3.6.1.4.1.8813.1.1.2.4.4.2.[ASCII values] See Syntax of OIDs referring to properties.
Alarm properties 1.3.6.1.4.1.8813.1.1.2.4.4.3.[ASCII values] See Syntax of OIDs referring to properties.
View properties 1.3.6.1.4.1.8813.1.1.2.4.4.4.[ASCII values] See Syntax of OIDs referring to properties.
Parameter ID (Information template) 1.3.6.1.4.1.8813.1.1.2.4.5.1 This OID and the below OIDs with prefix 1.3.6.1.4.1.8813.1.1.2.4.5 refer to the information template.
Custom Name 1.3.6.1.4.1.8813.1.1.2.4.5.2
Text 1.3.6.1.4.1.8813.1.1.2.4.5.3
Detailed Description 1.3.6.1.4.1.8813.1.1.2.4.5.4
Includes 1.3.6.1.4.1.8813.1.1.2.4.5.5
Category 1.3.6.1.4.1.8813.1.1.2.4.5.6
Corrective Action 1.3.6.1.4.1.8813.1.1.2.4.5.7
Alarm Description 1.3.6.1.4.1.8813.1.1.2.4.5.8
Filter 1.3.6.1.4.1.8813.1.1.2.4.5.9
Description 1.3.6.1.4.1.8813.1.1.2.4.5.10
Key point 1.3.6.1.4.1.8813.1.1.2.4.5.11
Offline Impact 1.3.6.1.4.1.8813.1.1.2.4.5.12
Component Info 1.3.6.1.4.1.8813.1.1.2.4.5.13
Exact Access Level 1.3.6.1.4.1.8813.1.1.2.4.5.14
Access Level 1.3.6.1.4.1.8813.1.1.2.4.5.15
Impacted Service Name 1.3.6.1.4.1.8813.1.1.2.5.1.2.1.1
Impacted Service ID 1.3.6.1.4.1.8813.1.1.2.5.1.2.1.2
OIDs of custom bindings referring to properties of elements, services, alarms, and so on, have the following syntax:
[Private enterprise][Skyline][Property][Type of Property][Name of Property]
  • Private enterprise: 1.3.6.1.4.1.
  • Skyline: 8813.
  • Property: 1.1.2.4.4.
  • Type of Property: A digit from 1 to 4:
    1. Element Property
    2. Service Property
    3. Alarm Property
    4. View Property
  • Name of Property: Property name spelled in decimal ASCII values (0-255), separated by dots.
Example:
The element property called "Redundancy Type" will be assigned the following OID:
1.3.6.1.4.1.8813.1.1.2.4.4.1.82.101.100.117.110.100.97.110.99.121.32.84.121.112.101
