Configuring SAML with Azure B2C as identity provider
From DataMiner 10.2.6/10.3.0 onwards, DataMiner supports Azure B2C as an identity provider for external authentication via SAML.
To configure this:
  1. Configure Azure B2C. See Azure Active Directory B2C documentation | Microsoft Docs.
  2. Set up an Entra ID Enterprise application. You can do this in the same way as for Entra ID.
  3. Create a DataMiner metadata file. You can do this in the same way as for Entra ID.
  4. Configure policies for Azure B2C. See Tutorial: Create user flows and custom policies in Azure Active Directory B2C | Microsoft Docs.
  5. Get the metadata URL:
    1. In Azure, go to App registrations, select your app, and select Overview > Endpoints.
      App endpoints
    2. Select the Azure AD B2C SAML metadata endpoint, e.g., https://dataminerservices.b2clogin.com/dataminerservices.onmicrosoft.com/<policy-name>/Samlp/metadata, and replace <policy-name> with the name of the policy you created earlier.
  6. Configure DataMiner to use external authentication. You can do this in the same way as for Entra ID.
    For the ipMetadata link, use the link created in the previous step.
  7. Configure DataMiner to automatically create users from Azure B2C. You can do this in the same way as for Entra ID.
    • If you use Azure B2C, users can only be provisioned automatically. Provisioning users by importing them is not possible.
    • To create SAML users in DataMiner using Azure B2C, a domain is required in the usernames. For this reason, email addresses must be used as the usernames. If the default username of the identity provider is not a valid email address, add a <PreferredLoginClaim> element to the <AutomaticUserCreation> element in DataMiner.xml that refers to a claim containing a valid email address.
