Configuring the necessary tags in DataMiner.xml
  1. If you want the DMA to forward alarm events via a particular TCP/IP socket, add an AlarmSocket tag and specify the socket in the port attribute.
    Example:
    <AlarmSocket port="5000"/>
  2. If you want to allow the DMA to forward information about elements and parameters when it receives a request on a particular TCP/IP socket, add a PollSocket tag and specify the socket in the port attribute.
    Example:
    <PollSocket port="5025"/>
  3. Save the DataMiner.xml file and restart the DataMiner software.
The DataMiner.xml file is not synchronized throughout the DataMiner System. It is unique for each DMA. As a result, you can have different socket configurations on each of your DMAs.
