Testing alarm forwarding
  1. Open a telnet session.
  2. Connect to the TCP/IP socket that is specified in the <AlarmSocket> tag of the DataMiner.xml file.
You should receive a message similar to the following one:
---id: 202871 previous: 202868 root: 202868---
            -> Element (2) Philips IRD
            -> Parameter (176): Audio Output Level
            -> Alarm Type : Dropped
            -> Value: 12
            -> Severity: Minor High
            -> Status: Open
            -> Time: 2012/07/18 19:26:44
            -> Userstatus: Not Assigned
Only raw alarms are forwarded via TCP/IP sockets. Alarm messages generated by the DataMiner Correlation engine, for example, are not forwarded via TCP/IP sockets.
