TCP-IP socket message reference
Message format
Each command or response must have a fixed header character and a fixed trailer character.
Header character: 0x09 (tab character \t)
Trailer character: 0x0D (carriage return character \r)
Commands and responses
Get_Alarm_Level (DMA)
Command
[Header]Get_Alarm_Level;[1][Trailer][1]
ip:[Primary IP address of the DMA]
Response
[Header][1];[2][Trailer][1] DMA ID
[2] Current alarm severity level of the DMA (see Alarm states)
Example
When a DMA receives:
\tGet_Alarm_Level;id:102\rIt will return:
\t102;3\r
Get_Alarm_Level (Element)
Command
id:[DataMinerID/ElementID] (e.g., 102/524)
ip:[virtual IP address]
Response
[Header][1];[2][Trailer][1] Element ID
[2] Current alarm severity level of the element (see Alarm states)
Example
\tGet_Alarm_Level;name:Paradise SSPA CO\rIt will return:
\t526;5\r
Get_Element_List (DMA)
Command
[Header]Get_Element_List;[1][Trailer][1] id:[DMA ID]
Response
A colon-separated list of elements:
[Header][1]│[2]│[3]│[4]:...:[1]│[2]│[3]│[4][Trailer][1] Element ID
[2] DMA ID of the DMA where the element was originally created
[3] Element name
[4] Virtual IP address of the element
Example
\tGet_Element_List;id:102\rIt will return:
\t261│102│Adam 6015:189│102│Cableworld CW-3823:175│102│Comstream ABR202\r
Get_Element_List (DMS)
Command
[Header]Get_Element_List[Trailer]Response
[3] Element name
Example
\tGet_Element_List\rIt will return:
\t261│101│Adam 6015:504│102│Newtec 2085:175│103│Comstream ABR202\r
Get_Parameter
Command to retrieve a normal parameter
[Header]Get_Parameter;[1];[2][Trailer][1]
[2]
tag:[ParameterAlias]
Command to retrieve a row from a table parameter
[Header]Get_Parameter;[1];[2];[3][Trailer][1]
[2]
- id:[ParameterID]
[3]
- key:[RowIndex] (Display key)
If you specify a table row key, then the parameter must be referred to by its ID. You cannot refer to it by its name or its alias.
Command to retrieve crosspoints from a matrix parameter
[Header]Get_Parameter;[1];[2];[3];[4][Trailer][1]
[2]
[3]
- x:[X-axis value of the crosspoint] (Use x:-1 to retrieve an entire row)
[4]
- y:[Y-axis value of the crosspoint] (Use y:-1 to retrieve an entire column)
Response
[Header]│[1]│[2]│[3]│[4]│[5]│[6]│[7]│[8][Trailer][1] Parameter ID
[2] Parameter name (as it is displayed on the screen)
[3] Parameter alias (if one is specified in the Protocol)
[4] Current value of the parameter
[5] Units
[6] Time at which the parameter value was first measured (format: YYYY-MM-DD HH:MM:SS)
[7] Time at which the parameter value was last measured (format: YYYY-MM-DD HH:MM:SS)
[8] Current alarm severity level of the parameter (see Alarm states)
If you requested crosspoint values from a matrix parameter, [4] will be a pair of x,y values for each connected crosspoint. Multiple pairs are separated by semicolons (";").
Example
\tGet_Parameter;id:102/526;name:Power Supply\rIt will return:
\t│526│Power Supply│C_PS1│11.2│V│2011-12-23 14:43:17│2011-12-23 15:03:17│1\r
Get_Redundancy_Info
Command
[Header]Get_Redundancy_Info;[1];[2][Trailer][1] DMA ID
[2] Redundancy group ID
Response
Name and ID of the redundancy group, followed by the colon-separated list of elements it contains.
[Header][A]│[B]│[C]│[1]│[2]│[3]│[4]:...:[1]│[2]│[3]│[4][Trailer][A] ID of the redundancy group
[B] DMA ID of the DMA where the redundancy group was originally created
[C] Name of the redundancy group
[1] Element ID
[2] DMA ID (as stored in the element)
[3] Type of redundancy group element (PRIMARY, BACKUP or STATE)
[4] ID of the virtual element. Only filled in if Type is PRIMARY
Example
\tGet_Redundancy_Info;5;10047\rIt will return:
\t10047│5│WMI Timeout group│ 10046│5│primary│10048: 10039│5│primary│10049: 9585│5│backup│: 9633│5│state│\r
Get_Redundancy_List (DMA)
Command
[Header]Get_Redundancy_List;[1][Trailer][1] DMA ID
Response
A colon-separated list of redundancy groups:
[Header][1]│[2]│[3]:...:[1]│[2]│[3][Trailer][1] ID of the redundancy group
[2] DMA ID of the DMA where the redundancy group was originally created
[3] Name of the redundancy group
Example
\tGet_Redundancy_List;5\rIt will return:
\t10047│5│WMI Timeout group:10017│5│RG_Some Channel\r
Get_Redundancy_List (DMS)
Command
[Header]Get_Redundancy_List[Trailer]Response
Example
\tGet_Redundancy_List\rIt will return:
\t10047│5│WMI Timeout group:10017│5│RG_Some Channel: 960│102│RG_RMS_2_ChannelY\r
Get_Service_Info
Command
[Header]Get_Service_Info;[1];[2][Trailer][1] DMA ID
[2] Service ID
Response
Name and ID of the service, followed by the colon-separated list of elements and services it contains.
[Header][A]│[B]│[C]│[1]│[2]│[3]│[4]│[5]│[6]:...:[1]│[2]│[3]│[4]│[5]│[6][Trailer][A] Service ID
[B] DMA ID of the DMA where the service was originally created
[C] Name of the service
[1] ID of the element or service that is a part of [A][B][C]
[2] DMA ID (as stored in [1])
[3] Indicates whether [1] is an element (TRUE) or a service (FALSE).
[4] Indicates whether [1] can be dynamically included or excluded (TRUE or FALSE).
[5] Indicates whether [1] is currently included or excluded (INCLUDED/EXCLUDED).
[6] Comma-separated list of parameter IDs, indicating which of the parameters of [1] are included in the service. If none are listed, then all parameters of [1] are included.
Example
\tGet_Service_Info;5;10056\rIt will return:
\t10056│5│SRV_Service_ChannelY│9605│5│FALSE│TRUE│ INCLUDED│:10060│5│FALSE│FALSE│ INCLUDED│23,24\r
Get_Service_List
Command
[Header]Get_Service_List[Trailer]Response
A colon-separated list of services and spectrum measurement points:
[Header][1]│[2]│[3]│[4]:...:[1]│[2]│[3]│[4][Trailer][1] ID of the service or the spectrum measurement point
[2] DMA ID of the DMA where the service or the spectrum measurement point was originally created
[3] Name of the service or the spectrum measurement point
[4] In case of a spectrum measurement point, the abbreviation “MP” is added after the name.
Example
\tGet_Service_List\rvIt will return:
\t627│101│S_DMA:502│102│Port01│MP:178│103│Serv_Test\r
Get_System_Info
Command
[Header]Get_System_Info;[1][Trailer][1]
Response
[Header][1]│[2]│[3]│[4]│[5]│[6][Trailer][1] DMA ID
[2] Computer name
[3] Time at which the DataMiner Agent software was last started (format: YYYY-MM-DD HH:MM:SS)
[4] Serial ports (number and names)
[5] IP address and subnet mask of all IP interfaces
[6] Network cards (number and MAC addresses)
Example
\tGet_System_Info;ip:10.11.2.1\rIt will return:
\t102│DMA-2│2011-12-23 11:05:31│ (2) : COM1;COM2│10.11.1.1-255.0.0.0;172.30.1.101-255.255.0.0│ (2) : 00-13-DA-58-8A-62;00-7C-49-69-74-9B;5\r
Get_User_Info
Command
[Header]Get_User_Info;[1][Trailer][1] Username
To get user info for a domain user, place the domain name followed by backslash in front of the username.
Response
[Header][1]│[2]│[3]│[4]│[5]│[6][Trailer][1] Username
[2] Full name
[3] Email address
[4] Telephone number
[5] Pager number
[6] Pipe-separated list of DMS groups of which the user is a member
Example
\tGet_User_Info;John\r
or
\tGet_User_Info;MyDomain\John\r
It will return:
\tJohn│John Doe│john.doe@skyline.be│051/313569│101│Administrators│System Engineers\r
Get_User_Info (list)
Command
[Header]Get_User_Info[Trailer]Response
A colon-separated list of users:
[Header][1]│[2]│[3]│[4]│[5]│[6]:...:[1]│[2]│[3]│[4]│[5]│[6][Trailer][1] Username
[2] Full name
[3] Email address
[5] Pager number
Example
\tGet_User_Info\rvIt will return:
\tJohn│John Doe│john.doe@skyline.be│051/313569│101│Administrators│System Engineers: Jane│Jane Doe│jane.doe@skyline.be│051/313569│102│Sales\r
Get_Virtual_Element_List
Command
[Header]Get_Virtual_Element_List[Trailer]Response
A colon-separated list of virtual elements:
[Header][1]│[2]│[3]│[4]:...:[1]│[2]│[3]│[4][Trailer][1] ID of the primary element
[2] DMA ID of the DMA where the primary and virtual element were originally created
[3] ID of the virtual element
[4] ID of the redundancy group of which the primary element is a member
Example
\tGet_Virtual_Element_List\rIt will return:
\t956│102│962│960:957│102│961│960:1023│102│1025│960: 1024│102│1026│960│10025│5│10029│10028:10024│5│10030│10028\r
Set_Parameter
Command
\tSet_Parameter;[1];[2];[3];[4];[5];[6];[7]\r[1] DMA ID
[2] Element ID
[3] ID of the write parameter
[4] If you specify “double” or “string”, the value will be converted accordingly. If you do not specify a type, the value will be converted automatically (when the value contains only numbers (or a decimal point), it will be parsed as double).
double
string
<empty>
[5] If [3] refers to a table parameter, then [5] has to contain the primary key of the table row.
[6] If [3] refers to a table parameter and you left [5] empty because you do not know the primary key of the table row, then in [6] specify the display key of the table row.
[7] The value you want to assign to the parameter specified in [3].
Response
0x09[1]0x0D [1] One of the following responses:
Response Description SUCCEEDED The SET command was executed successfully. ERROR: Not allowed Not allowed to perform SET commands via this socket. ERROR: General failure No connection with the DMS ERROR: Invalid nr of options xx need at least 7 Invalid command info ERROR: Setting the parameter-value failed. (xxxx) The SET command failed Example
\tSet_Parameter;5;20848;100;double;;;0\rIt will return the following if the SET command was successful:
\tSUCCEEDED\r
Alarm states
| Alarm state | Integer |
| Undefined | 0 |
| Normal | 1 |
| Warning | 2 |
| Minor | 3 |
| Major | 4 |
| Critical | 5 |
| Information | 6 |
| Timeout | 7 |
| Initial | 8 |
| Masked | 9 |
