Aborting a running automation script
To abort an automation script while it is running:
  2. In the Advanced menu, select Automation.
    The Maintain Automation window will open.
  3. Go to the Running Scripts tab.
  4. In the list of scripts, right-click the entry corresponding to the script you want to abort, and click Abort Now.
Warning
