Accessing script execution metrics
From DataMiner 10.4.11/10.5.0 onwards, the DataMiner Automation process generates the following script execution metrics:
  • Total number of executed scripts (including scripts that could not be started)
  • Total number of failed scripts
  • Duration of each script
  • Time at which each script was started
  • Users who started the scripts
  • Result of each script (success of failure)
To view these metrics:
  2. In the Advanced menu, select Automation.
    The Maintain Automation window will open.
  3. For information about each script execution, go to the Scripts Statistics tab and select Load/Refresh Scripts Statistics in the lower-left corner.
    Scripts Statistics
  4. For general information about script executions, go to the Automation Statistics tab and select Load/Refresh Automation Statistics in the lower-left corner.
Warning
