Configuring the frequency of smart baseline calculations
From DataMiner 10.2.7/10.3.0 onwards, you can change the frequency of smart baseline calculations using the SLNetClientTest tool.
On systems that aggregate large amounts of data from parameters with smart baselines, it can be useful to increase this frequency. By default, it is set to 5 minutes.
To change this frequency:
  2. Go to Advanced > Options > SLNet Options.
  3. In the dropdown box, select SmartBaselineThreadTime.
  4. Right-click the DMA for which you want to change the setting and select Edit value.
  5. Specify the new value and click OK.
  6. Click OK to close the SLNet Options window.
Warning
