Editing the connection string between two DataMiner Agents
In most cases, when you add a DataMiner Agent to a DataMiner System, all other DataMiner Agents in the DataMiner System connect to it using its primary IP address. However, in case e.g., NAT (Network Address Translation) is being used, you may need to configure the connection strings by hand. For more information about connection strings and how they should be used, see Connection strings.
  2. In the Advanced menu, select Edit Connection Uris.
  3. In the Connection String Configuration dialog box, right-click in the list, and select Add New Destination.
  4. In the Edit Connection String dialog box, configure the following settings.
    • From: The DataMiner Agent from which a connection will be made.
    • To: The primary IP address of the DataMiner Agent to which a connection will be made, e.g., 148.0.10.68.
      • For a DMA connecting to a Failover pair, this will be the virtual IP address of that destination pair. For a main Failover DMA connecting to its backup or vice versa, this will be the sync IP of that target machine.
      • Wildcards are supported in this field. If there is no exact match, the connection string will be set for all matching destinations.
    • Update All Connections To This Agent: Select this option if you want to update all connection strings to the DataMiner Agent specified in To.
    • New Connection String: The IP address to be used when connecting to the DataMiner Agent specified in To. For example: Syntax example: http://[IP address to connect]:8004/SLNetService.
      From DataMiner 10.3.0/10.3.2 onwards, you can configure a gRPC connection string. To do so, provide the full URL including the API Gateway, for example https://148.0.10.68/APIGateway. You will need to do so for each DMA in the system.
    • Username and password: The credentials to implement this change, if necessary.
    SLNetClientTest Tool: Edit Connection String
    Edit Connection String window in DataMiner 10.6.1
  5. Click OK to save the configuration.
  6. If no further connection strings need to be configured, click Done.
If DataMiner fails to automatically detect the SLNet target port (via port 80 or 443), the connection attempt will continue on the default port 8004. To skip this auto-detection and immediately use the default port 8004, you can set the connection string to auto://nodetect. This can for instance be useful in case port 80 is blocked between the DMAs.
To verify if your DataMiner cluster is working correctly, you can run the SLNet connections between the DataMiner Agents BPA test.
Warning
