Increasing the maximum upload size for upgrade packages in a DMS
The default maximum upload size of upgrade packages is 4000 MB.
However, it is possible to change the maximum upload size via the SLNetClientTest tool:
  2. In the Advanced menu, go to Options > SLNet Options.
  3. In the dropdown list next to Option values for, select MaxUploadSize.
  4. Right-click the indicated value for this setting, and select Edit value.
  5. Enter a new value and click OK.
Warning
This setting can also be customized directly in MaintenanceSettings.xml. However, this requires a DataMiner restart.
