Retrieving general information about elements
In some cases, it can be useful to retrieve information about elements via SLNetClientTest tool. This can for instance be the case in case you want to find the element ID for the hidden Skyline Generic Aggregator element of a DMA, as it can be difficult to find this information in a different way.
  2. Go to the Build Message tab of the main window of the SLNetCLientTest tool.
  3. In the Message Type dropdown list, select GetLiteElementInfo.
  4. Configure the fields of the message according to your preferences.
    • You can for example set IncludeAggregatorElements and IncludeHidden to true to get info for the hidden aggregator elements in the system.
    • In the NameFilter field, you can specify a filter with an asterisk (*) wildcard in order to only retrieve information for elements matching that filter, e.g., Skyline Generic Aggregator DMA*.
    • From DataMiner 10.6.0/10.6.3 onwards, you can filter elements by HostingAgentID. This allows you to retrieve only the elements that are hosted on a specific DataMiner Agent.
  5. Click Send Message.
  6. Select the top message in the Properties pane.
    The retrieved information will be displayed in the pane on the right.
