Retrieving live information about the mapping between elements and the processes they use
From DataMiner 10.5.4/10.6.0 onwards, it is possible to retrieve live information about the mapping between elements running on a DataMiner Agent and the processes they use, including SLProtocol and SLScripting. The information provided is similar to the information found in the SLElementInProtocol.txt log file. This can for instance be useful to monitor and troubleshoot process usage in real time.
To do so:
  2. Go to Diagnostics > DMA > Element Process ID Info.
  3. Under the Properties tab, double-click the newly created Message Info Table entry.
    This will open a new window showing an overview of your elements.
    Row format: Element/SLProtocol Pid/SLScripting Pid.
Warning
