Launching the standard Booking Wizard from a custom script
You can configure a custom frontend script to launch the standard Booking Wizard, and even provide default values for specific fields (service definition, timing, resources, etc.).
To do so, use the same code as is used to silently create a booking, but use the overloaded CreateNewBooking method that accepts the IsSilent input argument:
reservation = bookingManager.CreateNewBooking(engine, bookingData, functions, customEvents, properties, false);
