Silently adding properties to an existing booking
The example below shows how properties can be added to an existing booking without user interaction by means of an automation script.
using System;
using System.Collections.Generic;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
public class Script
   public static void Run(Engine engine)
      // Update with relevant data
      var reservationId = Guid.NewGuid();
      var propertyName = "Property";
      var propertyValue = "Value";
      var properties = new Dictionary<string, object> { { propertyName, propertyValue } };
      var reservationInstance = SrmManagers.ResourceManager.GetReservationInstance(reservationId);
      reservationInstance.UpdateServiceReservationProperties(properties);
