Silently applying service state transitions
The example below shows how you can apply service state transitions (Start, Stop, Pause, Standby, etc.) or force the same service state without user interaction by means of an automation script.
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
using Skyline.DataMiner.Net.ResourceManager.Objects;
public class Script
   public static void Run(Engine engine)
      // Replace with reservation guid
      var reservationGuid = Guid.NewGuid();
      var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationGuid) as ServiceReservationInstance;
      var bookingManager = reservation.FindBookingManager();
      // Apply service state async
      bookingManager.ApplyServiceState(engine, reservation, "STANDBY");
This call will run asynchronously. An overloaded method can be used to run it synchronously.
